CO2 removeall at wellhead
Has anybode heard of (novel) technology to remove CO2 (4-6 mol%) at well head (no bulky/complex equipment)? HP/HT conditions. Link to manuf. would be greatly appreciated.
Best Regards
Morten Andersen
RE: CO2 removeall at wellhead
Can anyone tell me if there would be a corrosion concern for CO2, (0.54 mol%) in separator gas, (0.38 mol%) in separator liquid, and (0.572 mol%) in flash gas? Piping is A106.  Guidance of any kind is appreciated, consultants in this area, etc.
Louis Routier III
It will depend op your operating pressure/temp. If you want to check it out yourself then the Norwegian Oil industri has a standard that comes with a spreadsheet for checking coorosion. But you have to have some starting knowledge.
http://www.nts.no/norsok/m/m50601/m50601.htm
best Regards
Morten
PS Dont be afraid to start a new tread.
Morten  I tried the address but it moved  I can no get there  can you help me please??
They changed the layout.
Try http://www.nts.no/norsok
and navigate from there. Its under M for material.
Best regards
Morten
Morten, Thanks a lot for the info. It is very useful. Regards. Attilio
contact arbochim@online.be  we have the right answer
the answer to what?
Marten,
Found it.
This article by TE Cooley and WL Dethloff of Grace Membrane System, Houston TX, in CEP October 1985 will interest you.
The flow scheme start from the wellhead to a heater treater, prefilter coalescer and finally to a membrane filter prior to sells.
Englehard has the Molecular Gateā„¢ system for small rates.
