For AISC, which method, LRFD, or ASD, should one use ? ?
I am a Structural Engineer in the oil and gas industry, in Aberdeen, Scotland, U.K.
In this industry we use some of the American codes, e.g. the AISC codes.
ASD is the allowable stress design. I have the 'green book', 9th edition, dated 1997.
Has this method been replaced by LRFD ?
Presumably this is a Load Factor Design method ?
When did this method come out ?
Is ASD still valid ?
Which of these 2 codes is the most commonly used code, in the U.S.A. ?
In terms of column design ( combined compression, and bending ), is there any difference between the methods in these 2 codes, aside from load factoring ?
RE: For AISC, which method, LRFD, or ASD, should one use ? ?
It is better to use method that you are familiar with.
LRFD is more advanced, so you might get smaller sections for the same load.
On another hand, California requires that schools and hospitals to be designed using ASD, since it has larger Factor of Safety.
Good luck.
LRFD never picked up the momentum in the US. I am not sure why. There are several factors one of which is the engineering graduates of the late 70s and early 80s,were not educated in the use of LRFD. As humans we become comfortable in what we use and refuse to change. Another reason is ASD has performed well for steel design in the US, which made lots of engineers ask why change now.
AISC attempted repeatedly to encourage the use of LRFD and the success rate is not as they desired.
I maintain that once recent college graduates center the market, they will force the market to use what they have been educated and trained on.
Bottom line, use the method that you feel comfortable with and one that you can substantiate results.
ASD is always valid. LRFD (load resistance factor design) is the new method and is slowly begining to find its way in since, as whymrg mentioned, can lead to some savings in material.
I dont know if you are at the offshore or onshore end of the oil industry, but the API code for offshore platforms (the latest I worked with 1993) does not (did not) recomend LRFD or LFD.
In column design, as long as you apply the appropriat factors to loads and material strength the idea is the same. A book by Salmon and Johnson titled "Steel Structures, design and behaviour" is a good source. I am sure there are many others.
more twisting in a high wind. Thus is it safer. Also a better weld will develop when the shear tab is welded. Both items increase the proformence of the building package.
The codes establish minimums. Nothing stops you from doubling the size of everything just to be safe. The question is how safe is safe enough? If LRFD yields smaller members (which, overall, it is known to do), does that mean it's dangerous, or that ASD was overconservative?
The main reason ASD is preferred is because it is familiar, period. (Same reason the US still hasn't gone metric, but the metric threads are over in another forum.) It was also preferred because it was simpler, but the upcoming Grand Unified AISC code makes things equally messy for both methods; from what I can see only the factors are different. AISC has a review copy on their website at http://www.aisc.org .
There was another thread (perhaps in another forum) that had some pretty good ASD vs. LRFD discussion but I can't find it now. Perhaps someone with more patience than I have can locate it. (Is the keyword search function going to be fixed?) Anyway, in that thread someone pointed out that it's mostly LRFD being taught in the schools, and that it will be used more and more often as engineers enter the workforce who learned on that method.
That's not to say I don't love my Green Book.
Hg
One proof - for a structure with a very high amount of live load relative to dead load, the safety factor on the design would approach 1.6/0.9 = 1.777 for flexure while in ASD it is 1/0.6 = 1.666.
LRFD is simply a better way to weigh the differing variabilities in loads and resistance in a statistical manner. ASD is simply a selected safety factor regardless of the variability of the applied loads or resistance. So in once sense, ASD is LESS safe in that it doesn't consider these valid variabilities.
Both LRFD and ASD have been fully adopted in the International Building Codes in the US and in fact, AISC will soon present its new combined LRFD/ASD specification where ASD has been finally upgraded to reflect current research and knowledge. This will make ASD a bit more cumbersome to use but granted, many US engineers prefer to stay with what they've used for the majority of their careers.
I agree with Lutfi that over time, LRFD will become more dominant as the engineers who use ASD will retire.
ASD's safety factor is not necessarily a "safety factor", it could turn out to be an "unsafety factor", because ASD treats all types of loads as one type which has been proven to be wrong based on statistical studies.
For regular beam design, it does not matter whether you use ASD or LRFD, but if you have unusual situations ASD manual can not help you. Example, if a contractor asked you to evaluate of an existing plate bending in strong axis, what do you say to the contractor? That I do not how to do it? There are many structures (existing or new), ASD will prove to be unsafe, but in fact they are not.
The thing to remember is that ASD or LRFD specifications (green manual and silver/blue manual) are not ***legal*** documents. These specifications are adopted by the building codes by reference with some modifications.
For seismic design, code provisions for ASD are becoming similar to LRFD provisons. For drift calculation, you can not use ASD load combinations, but you are allowed to use ASD for design.
Prevalence of ASD in US is comparable to the prevalence of imperial system (inch, pound, kips, mph... system vs SI system) -- because of resistance from the building industry to change. My bosses never opened LRFD manuals in their whole lives and they are in the code committee. See!
However, you should be following the method that is common to your industry. Building structure are different than other structures -- if you ask a building engineer to design a car chasis [using ASD :)], you will be getting a humvee!
On positive note, LRFD resolved the long standing debate regarding the use of 33% stress increase (which in my opinion was abused by many engineers). When using factored loads we totally do away with the need to increase stresses by 33%.
It bothered me to no end that engineers were increasing allowable stress by 33% when they had dead load and wind loads acting!
The reason why I am so interested is because I am writing a spreadsheet, to do AISC ASD combined bending and compression design.
You have all convinced me that the ASD design has still got a very good future.
my opinions are as follows :-
1) Both our steel and reinforced concrete codes in Britain are Load Factor ( or as we say limit state )I have never liked these methods. It seeems to me to be ridiculous to go to all the effort to have different load type factors, when the materials used have such a large strength variation, especially concrete.
2) I dont think their is sufficient difference in the load factors to justify them, e.g. :-
a) Dead + Live = 1.4Gk + 1.6Qk
b) Dead + Live + Wind = 1.2Gk + 1.2Qk + 1.2Wk
Basically I believe that it has become unecessarily complicated ( numerous load combinations ), and I don't believe that it has succeeded in saving much material.
As you will know, the UK's allowable stress steel design code - BS449 has not been withdrawn.
I've used the UK ultimate limit state code - BS5950 for all of my career and have only checked other peoples calulations done to BS449.
I take issue with your comment on the magnitude of the partial safety factors. 1.4Gk+1.6Qk can be VERY different to 1.2(Gk+Qk+Wk). Also don't forget 1.4(Gk+Wk) and 1.0Gk+1.4Wk....
The main point is, we work out the effects of the different ULS load combinations then design for the worst case. In many cases the worst case is blindingly obvious and then there is only one case to consider!
Yes you are correct Gk and gk are dead load, Qk and qk are imposed (live) load and Wk and wk are wind loads.
The capitalised terms are the total loads and the lower case versions imply contributing loads.
If anyone out there knows why G and Q are used please let us all know!
thanks for the education
http://www.eng-tips.com/viewthread.cfm?qid=67167
Part of the problem has been that all of the "players" haven't been at the discussion table when USD/LRFD were developed. Geotechnical engineers, in particular, have problems with LRFD - see the thread above for a more complete discussion.
Until AISC recognizes the very real and serious limitations in LRFD - and moves to deal with them by dialogue, not fiat - resistance to LRFD will continue. Some may be reluctant to use LRFD because of their comfort with ASD. That's not my reason -
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
The question had to do with AISC, not AASHTO (or whoever covers piling, foundation, and retaining wall design).
Hg
From what I also remember at the time that LRFD came on the scene for steel design, savings of a few percent were being realizied on large commercial type projects. However, in industrial allpications there are too many situations where we want there to be additional safety factors that combined with non-symmetrical, low redundant type configurations did not warrant in my opinion the use of LRFD.
vmirat: If neither code is specifically required, you pick one and follow it. You are under no ethical obligation to do multiple calculations and pick the "safer" one. If it were all about "bigger is better", you'd be under some kind of obligation to just provide the biggest member that can fit into the space available--nothing prevents you from oversizing members beyond code requirements. As long as you follow any one of the allowable codes, the liability is not on you any more than it would be if there were only one allowable code. LRFD has been used to reanalyze structures designed with ASD when a potential overload problem arises.
pmkPE: the simplicity of ASD (within AISC anyway) is about to go away, as others have said. The calculations will be the same for either "method" (one can hardly call them separate methods any more); only the factors are different.
"All steel will be designed to ASD"
Peace berty
