11KVA Power Cable Interference
We are installing a CNC laser cutting machine &
there is 11KVA power cable running under our workshop
about 600mm to 1000mm under the floor. Is it possible that this could interfere with the machine . The cnc control cabinet would be not directly over the cable but the servo motors & other cables would travel over the cable when cutting down that end of the machine.Is it possible to estimate or measure if this may cause interfence or not
Would putting a earthed steel plate 1000mm wide in the floor along where the cable is help ?
Steve C
Steve C
RE: 11KVA Power Cable Interference
well you have to think about fields here, current flows through the cable produce the fields and as you can imagine at 11kv the current flow is pretty small compared to say a service cable running at distribution 240/415v 3ph. Id say go with the metal plate as a cover and as the 11kv cable has all the cores close the interference problem should not materialise. take it that the cable is suitably screened and covered at present ?
Rugged
Bung
Life is non-linear...
And, please: If there should be any problem with this new installation - don't blame the cable. I have seen otherwise perfectly sound people blocked and passivated by exactly such things. Instead of finding out where a shaft jams or the alignment is bad they blame something that has nothing to do with the problem. Like your cable.
I was really concerned about putting the machine over this cable - it's looking like it won't be a problem !!
steve
Just use a little restraint drilling anchor holes in the floor. ;-]
