Copy/Paste Break Link
I have a Main_Product that contains a Sub_Product that contains several Parts which are linked to other things in the Main_Product.
I would like to create another version of the Sub_Product within the Main Product that is not linked to the original Sub_Product.
I tried Copy+Paste+Break_Link and this created a new Sub-Product that was not linked to the original.  However, all the Parts within the new Sub_Product were linked to the parts in the original Sub_Product.
Is there anyway to break the links of all the parts as well?
Thanks in advance.
RE: Copy/Paste Break Link
Only one at a time, as far as I know.  You need to do the COPY/PASTE - BREAK LINK for each.
There is an alternative - If you own a PKT license, you can set up a Product Template which will allow you to do this.
If you want to create new components i.e. new part numbers do a new from on the sub-product and in
the list of parts do new from on each part then if there are any links still within these parts isolate the individual parts, doing a copy and paste will just create a new instance of the part, if this is what you want to do i.e. a new instance there is no way of breaking the link between the parts in the two sub-products as they are the
same part
Update:
The best solution seems to be:
a) Create a new Sub_ProductB under Main_Product
b) Select all the parts in the existing Sub_ProductA
c) Copy and Paste - Break Link into Sub_ProductB
d) Right Click on each of the pasted components and Define Contextual Links.
e) Update.
