How do you weld?
How do you weld?
Sorry to ask such a basic question but this wasn't covered in my level 1 solid works class. How do you weld pipes together for example, if you have a pipe or tube 12 ins long and weld another pipe in the center of it at 90deg? How is the weld performed or shown.
RE: How do you weld?
Part - You use Weldment Toolbar. There you can add welds simply by selecting the "Fillet Bead" Icon
Assembly - You have go to Insert\Assembly Feature\WEld Bead - it makes a new part and you pick the appropriate faces to apply the bead.
I personally would use the Weldment toolbar at the part stage. I used it to make a tubed bumper for my truck. However I did use SW05 because it supported the bending of tubes (For the push bar) were SW04 didn't.
You can see the weld beads under each pipe.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
