residential home wall reinforcement against shear load
I am a mechanical engineer, I have a good knowledge on steel structures, but almost nothing when it comes to bricks or concrete.
I need to reinforce my house wall. I think the structure what was asked for is what you call shear frame, but please correct me if I am wrong.
In practice I have a small gap (2.5 metres) between my house and a steep mountain wall behind it. As there was a change in the local regulations, now I am obliged to fill up the gap between the house and the mountain wall with earth. There is a concern that the filling material will push the wall of the cellar in. I have a corridor next to that wall. According to the current design a pair of red brick pillars of 25x25 cm shall be placed with a concrete arch above them to the middle of the corridor like in mine shafts, and furthermore I have to put an extra layer of bricks 3 metres long next to the non-load bearing wall located perpendicular to the inside brick column2 on the other side of the corridor wall.
gap to fill
---------------------------external wall
O column1
[ arch
O column2
---------------------------internal wall
|| reinforced
This will cost a lot. The idea is to replace the whole structure with steel frames which is cheaper at this part of the world. However, for that, I need to understand the concept presented above to make sure that the new design will be safe. I can not find any info about how to estimate the strength and load bearing capacity of such brick pillars, arches, walls, and the shear load of the earth to a wall. Can anyone help me where to find the data I need?
gsc
ps: sorry for the looooong question :|
gap to fill
O column1
[ arch
O column2
|| reinforced
gsc
RE: residential home wall reinforcement against shear load
