Best Pro Engineer to buy
What is the best Pro Engineer Wildfire entry level package available? Is Foundation Advantage good value?
RE: Best Pro Engineer to buy
The answere is "it depends." What do you want to do with it?
Best regards,
Matthew Ian Loew
"Organizations cannot make a genius out of an incompetent. On the other hand, disorganization can scarcely fail to result in efficiency." -- Dwight D. Eisenhower
ProEpro
www.whitelightdesign.com
Pro/E FAQ www.whitelightdesign.com/servicestips.htm
We use the Foundation Advantage II package here, it's perfect for what we do.
It has the perfect combination a advanced options, sheetmetal, Mechanisms etc. you could probably get a license around $4,000.00
I do alot of motion analysis of small block chevy combinations and Wildfire works perfect for this. The majority for everything else we use the software for is oilpans, vaccuum pumps, fixtures etc..
Even thought you may not originally conceive of using them, I have found the modules for Behavioral Modeling (BMX) and Mechanism Design (MDX) indispensable in my work. I would recommend any body trying to purchase Pro/ENGINEER to make sure they get these modules. My understanding is that they are included in Foundation, but I can't be sure with all of the "special offers" that may be made.
Good luck!
Best regards,
Matthew Ian Loew
ProEpro
