Saturated steam measurment
Trying to measure the discharge flow from a steam jet ejector. The motive steam is superheated, suction is off of a vessel of boiling water, and I'm told that many attempts to measure the discharge steam flow have failed due to it possibly having water droplets. A vendor of a V-Cone meter told me it would work, but I'm hesitant to cut into a 12" line if I'm not sure. Any suggestions? We're currently using several calculations based on jet pressures & energy balance and they never match up...
Dean
Dean
RE: Saturated steam measurment
If the steam is really superheated in can NOT have water droplets, agree?
You may try a Vortex measurement.
Vortex meters are used in numerous branches of industry to measure the volume flow of liquids, gases and steam.
Applications in the chemicals and petrochemicals industries, for example, in power generation and heat-supply systems involve widely differing fluids: saturated steam, superheated steam, compressed air, nitrogen, liquefied gases, flue gases, carbon dioxide, fully demineralized water, solvents, heattransfer oils, boiler feedwater, condensate, etc.
Vortex meters are particularly popular in all sectors of industry for metering steam.
Vortex meters measure volume flow, but steam systems are generally rated by mass or energy content, so these meters are frequently used in combination with a pressure and/or temperature sensor and a flow computer.
The Prowirl 73 vortex meter combines everything necessary for the direct mass metering of saturated steam:
flow computer, temperature and flow metering all in a single device.
http://www.endress.com
Hope this helps,
CARF
CARF, i agree the superheated steam won't have droplets, just not sure what's coming out of the jet. In the past they've tried ultrasonic (poor signal), turbine (fouled), and venturi (unstable signal). Didn't try vortex. Would vortex be ok if there were droplets? i.e. the jet suction pot may not be designed with enough de-entrainment height? I believe vortex also requires some straightrun, so we may be doomed by the tight piping.
Dean
Mat bal on the measureable streams seems about as good as you can get on this one, good luck
Thanks again,
Dean
