Defining Longitude and Latitude Angles
Can someone guide me how to define the longitude and latitude angles to a line in a 3D sketch.
RE: Defining Longitude and Latitude Angles
Use planes and dimensions.
Relations may also come in very handy depending on what you are doing.
A mixture of both is the best way.
Jim
NZ
Can you define your question better?  Are you using the 3D Sketch tool?
If so, you can use the Tab button to change which planes you are sketching on, and add dimensions for angels as required.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Selecting your tab adjusts the XY, YX, ZY, ZX option while making your 3dSketch. If that's not what your looking for, then offset planes as needed first. Then when using lines in your 3DSketch you can make collinear relationships to them. With a spline you can only add Coincident relationships between the points.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
