Exploded view collapses
I have an assembly with two cfg's...one cfg has an exploded view the other not...when I switch between cfg's the exploded view collapses automatically and I have to dbl click it every time to explode...is there a way to always have the cfg remain exploded when I switch between cfgs?
Thanks in Advance,
SWCADMAN
Thanks in Advance,
SWCADMAN
RE: Exploded view collapses
The Exploded config is a derived config, so the parent config must be active before the child can be activated. So you can't switch to the parent config and expect it to stay exploded.
So before you ask... It works the same way in SW05.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
