"Standard" Sheet Metal Tolerances?
Is there such a beast?  Is there a more current version of ASTM-A-480-99b than 03/01/2002?
Our company has set standards for 10ga SST 304 of .145-.130, but we have changed vendors and they provide .147-.135  They claim conformance to the above specification.  I am aware that tolerances will vary depending on the mill.
I've checked eFunda, but they do not list tolerances, only nominal gages.  Any help welcome.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: "Standard" Sheet Metal Tolerances?
ASTM A 480/A 480M - 04 is the most recent revision of this standard.  Tolerances will depend on product form (sheet, strip, width, etc.) but for hot-rolled wide coils & cut lengths, the tolerance on thickness is + 0.012 in. [0.30 mm] for specified thickness of > 0.130 [3.30 mm] to 0.145 in. [3.68 mm] and 0.013 in. [0.34 mm] for specified thickness > 0.145 in. [3.68 mm] to 0.1875 in. [4.76 mm].
