Beam Design using unequal angle
Hi!
I am junior engineer and I try design beam using unequal angle according AISC. In chapter F, "Beams and other flexural members" of the standard noted that: "This chapter applies to singly or doubly symmetric beams" and unequal angle is not singly or doubly symmetric beam.
My questions are:
-According which chapter of the AISC should I design angle beam?
-Where could I find some design example? Could someone send me design example of such beams?
Thank you very much,
Jav
My questions are:
Jav
RE: Beam Design using unequal angle
It has theory and tables for Fy=36ksi and Fy=52ksi.
You may get this article on www.aisc.org go to ePubs and then Engineering Jurnal and search for this article.
AICS has a fee, but you get good info for it.
Good luck.
