pros and cons of PVD coating
Does anyone know how wear resistant this coating is?  I'm considering using a black pvd coating, but i'm rather concerned that the finish won't last.
Any opinions would be gratefully appreciated
Bry
RE: pros and cons of PVD coating
Bry
You need to specify the material that you will be using.  PVD (Physical Vapor Deposition) is the process by which the coating is applied.  A variety of materials can be used depending on the desired properties.  PVD is used to hard coat metal cutting tools such as milling cutters so I imagine that the wear resistance achievable is excellent
Rich
Rich,
Sorry for being abit vague, but i'm actually unsure of the coating, the coating is used on the recent SBS(Special Boat Services similar to SAS) Dive watches.  The RN dive watches are plain SS cases probably 316L.  Would you say that this process is like hard anodising?
Anyway thanx for replying
Bry
Hi Bry
I looked into PVD a couple of years ago when I was in the UK.
I suggest that you contact a company called Balzers (not sure of the spelling) in Milton Keynes.  They were very helpful to me and I bet that they would know what you are talking about.
Hope this helped
Rich
