Pros and cons of PVD coatings
Does anyone know how wear resistant this coating is? I'm considering using a black pvd coating, but i'm rather concerned that the finish won't last.
Any opinions would be gratefully appreciated
Bry
Bry
RE: Pros and cons of PVD coatings
TiN - 2300 HV(microhardness)
TiCN - 3000
CrN - 1750
TiAlN - 3500
CrC - 1850 HV(microhardness)
Is there anybody who can answer the following on PVD coatings ;
1) What is the corrosion resistance of the PVD coatings (TiN / CrN / CrC) ? Any data on Salt Spray resistance test as per ASTM B117 ?
2) Any data on following properties of PVD coatings
Bond Strength (ASTM C633)
Erosion Resistance (ASTM D968)
3Cr13 cuttings by column arc PVD coating TiN 50 min,thickness about 1 u,
Salt Water marinate resistance for 6 hours, some rusted.
with pure Ti 15 minute below TiN, much better in the Test.
CrN might be better.
