Dimensions do not show up on screen, but do show on print
I completed a print, printed it and saved it. Everything looked good. When I re-opened it, many dimensions did not show up on the screen. They appear on print preview as well aas actual print. If you click around the general area where these dimensions should be, you will be able to blindly select them and they will appear until un-selected. I made sure layer was on. I found that if I selected it and changed the color from white to green, it then appears. I can change it back to white and evrerything appeaars fixed. Any ideas?
RE: Dimensions do not show up on screen, but do show on print
I have found more specific details on what causes dimensions to re-appear.
I can blindly select the dimensions in the layout tab when in model space inside the viewport. However, from here, I cannot change the color, change it back and have it remain viewable on screen. To do this, I must be in Model tab. Also, I found that changing other properties (and changing right back) also works. Example - changing to a hidden line and back to continuous. I now found out that I can blindly select the dimension and open properties. I can open the color pull down window and click on white (was already white). This is enough to fix problem. Also, I can hit undo as many times as I want and it remains fixed????? I have talked to someone else that had the same proble and does not know solution. Aany ideas??
try to lower ur resolution of the video card..if no that
try to change the font to a romans or a std. txt
try those if not post back
Joey Baggs
One more piece to the puzzle....then I give up?
The dimensions all dissapear as I stated earlier in the string.....One dimension does not dissapear and that dimension was made with a quick leader and text (not an actual dimension)
HAS ANYONE HAD THIS HAPPEN?
sundemon
