Stainless Steel Pipe
Does anyone know of any specific plumbing codes that specify stainless steel pipe material grades permissible for potable water? I'm mainly interested in codes for use in cold water applications and limitations that may apply.
Thanks.
Thanks.
RE: Stainless Steel Pipe
try: http://www.epa.gov/ORD/NRMRL/wswrd/epanet.html
Carpenter has good tech info: http://www.cartech.com/
NiDI has lotsa info, too: http://www.nickelinstitute.org/index.cfm/ci_id/45/la_id/1.htm
Be sure to passivate - see if you can get water chemistry test results from the water dept [chlorides etc.]
