Stainless Steel & Potable Water
Does anyone know of any specific plumbing codes that specify stainless steel pipe material grades permissible for potable water? I'm mainly interested in codes for use in cold water applications.
Thanks.
Thanks.
RE: Stainless Steel & Potable Water
Why would you want to use stainless steel, anyway?
It would be more expensive than the allowed materials and because of the chlorine in the water, I would be concerned about corrosion.
