Assembly Design
Assembly Design
Correct me if i'm wrong, but didn't there used to be a function within the Assembly design sectioning tool, that allowed you to save the resulting 2D cut. I think it was there around R10, we are now using R12 sp6, and I can't find it anywhere.
Any help would be greatly appreciated.
Cheers
Cheers
RE: Assembly Design
we're using R12 SP3 but I think it's the same in SP6.
In the sectioning definition choose "Result". There you find an "Export As"-Icon on the lift side.
Hth
bigcheese
RE: Assembly Design
What package is that associated with? When I go to the result tab there are 3 icons, 'volume cut', 'edit grid' and 'results window'. There is no icon to 'export as', although this was the icon I remeber using in previous releases.
We are running MD2 package + GSD2 add-on license.
I presume that this doesn't include the 'export as' function. Does anyone know what package contains this?
RE: Assembly Design
greetings
RE: Assembly Design
Your probably need Space Analysis License (SPA) to get those "SaveAS" tab up.
Cheers. Kennis Tang.
