Cutting external threads
I was wondering if there was something as simple as "Hole Wizard" available for showing external threads on a part?
Currently, I add a helix to the portion that I want to show threads on. Then I sketch the triangle made by one thread using 60deg, and the minor and major diameters. I then finish it by making a sweep-cut using the helix and sketch.
Any better ideas?
Any better ideas?
RE: Cutting external threads
Here is a part that consists of 2 different configs.
One represents Threads with a helix, plus a runout. The other Configuration represents fake threads by doing a cut-revolve and then Linear patterning it.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Go to Insert, Annotations, Cosmetic Thread...
Scott Baugh, CSWP
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
e.g. Drawings
Scott Baugh, CSWP
Ray Reynolds
When you sketch these diameters you think that they are ok. But when you exrude the model thru a helix, and then remeasure these diameters, you will find they are no longer accurate. - No idea why - it just is!
I give the thread a callout on the drawing to note exactly what it is.
