Spaceball Settings
Spaceball Settings
Has anyone had issues with NX 2 not keeping you 3D input device settings?
I am using a spaceball 4000 flx. And even if I set all sensitivity buttons to max it is still slow in NX 2. Then when I adjust the setting in UG it will only keep the setting in that session.
Any suggestions?
Any suggestions?
RE: Spaceball Settings
UG_3DInputSensitivity:
If you increase this value it should increase the default sensitivity. We run on 6 as default on our 3000/4000/5000's on NX2.
The new USB spaceballs seem to be much more sensitive out of the box that the serial ones...
Hope this is some use.
Simon C
