dashed lines appear continuous
I have always had problems when trying to use dashed or hidden lines. Sometimes they work great, other times they just show up as solid???????????. I try changing scale, etc, nothing seems to work. Any ideas
RE: dashed lines appear continuous
if your drawing is at 30 scale, then your Dimscale should be 30 and your ltscale will also be set at 30.
CadtechVA
