Separating Mold Components after Cavity Command
Okey.
I have a part i am going to cast out of aluminum. I will use a three part mold. Think of a fat bottom wine bottle without the bottom wall, and a flanged spout.
So I will have a male mold for the inside and two females for the outside.
I started by placing my part in a new assembly and then making a new part which consisted of a Huge box around my part. Then i hit the mold>cavity command and it hollowed out the box in the shape of my part. So now i have a box which has a void somewhere inside there.
I copied the box file, made like 4 or 5 copies just in case. Now the problem is, how do i go about splitting the male mold for the inside.
It is a free floating part, YET it is one with the box, so i cannot separate it. I am sure this is very simple.
I am running out of ideas, please help. Also, if you think there is a better way to do it, i would appreciate it greatly.
Thank you in advance.
RE: Separating Mold Components after Cavity Command
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Take this box part with the cavity in it and use it as a base part. ie, open a new part file; Insert,part and browse to your box/cavity part. Then take that base part and remove either the inside or outside using a cut-revolve. When SWX asks you which body you want to keep, pick just one. Then the next time you do it, pick the other one. Eventually you should end up with all of the individual parts you need.
There are other ways to do this as well. Another way would be to rollback your box part to before the cavity feature. Slice the ends off your box at the ends of the part. Then your cavity will end up being 3 separate bodies.
