Countersink Fillers
Countersink Fillers
Has anybody encountered the little conical fillers that can be used in repair work to fill the countersink when one applies a doubler over top? I've been shown these before by a repair shop, but I can't find my notes where I wrote the part number to call out. It was a Boeing p/n, as I recall.
Steven Fahey, CET
"Simplicate, and add more lightness" - Bill Stout
RE: Countersink Fillers
I believe you are refering to repair washers, Boeing p/n 66-02955.
jetmaker
I'll try a sketch to illustrate what I mean:
_______ _________
_______| |_________ New layer
_______\ /_________ Filler in this layer's c-skink
_______| |_________ Existing layer
Steven Fahey, CET
OEM engineering had us shoot a csk AD rivet in the discrepant hole, then re-drill, creating our very own repair filler. This worked with Doubler only.
This from my "Structural Repair Memory"
I didn't substantiate it because it came from OEM with an 8110-3.
Cheers.
By the time I got back, he'd already done it according to his own plan. Sigh. When you're called in as a consultant, the shop floor guys don't feel as motivated to do exactly as you say...
Steven Fahey, CET
But, Inspection ALMOST ALWAYS wants to see the substantiation for the repair. Bless their Hearts.
I'm thinking about having "I told you so" stickers printed and just hand them out. (But that would be a display of "Bad Attitude" and we wouldn't want that!)
Who is that comedian that hands out "Stupid" signs?
Sorry, I digress.
I'll try to find this in the SRM...I just can't remember exactly where in CH 51 it is. (Used to know...getting Old)
Rerig
The p/n I provide is the Boeing part number. A dash number follows specifying what the appropriate dimensions should be.
For example, 66-02955-51 is a repair washer for a 100 deg tension head 3/16" Hi-Lok. A -52 is for the same fastener, but 1/4" diameter.
Hope this is useful.
jetmaker
How about the dash number for a 1/8" rivet with a reduced countersunk head? This is a case where a NAS1097AD4 was drilled through.
Steven Fahey, CET
Sorry, but from my sources, there is no Boeing part number repair washer available for such a small csk depth. I do have one for a 1/8" MS20426D rivet (-1) or a 5/32" CE rivet (-47). The csk depths on these repair washers is 0.048" and 0.035" respectively.
Wish there was more I could do. If you find another p/n, let me know.
jetmaker
