Magmeter Accuracy?
Magmeter Accuracy?
Is there any method short of taking out the Tube and sending back to a flow lab or verifying or checking accuracy of installed unit? Anyone have a way of doing a local "bucket test?" that is acceptable??
RE: Magmeter Accuracy?
Otherwise, go with Khan's suggestion. I will prefer a Corriolis Meter.
what is your accuracy requirement and what is its basis?
Dean
Coriolis meters worked for me, We have about 40 installed. We took them in our preventive maintenance program. Every two years we flush and clean them because our product is leaving a small film on the inside of the two tubes of the coriolis. Which have effect on the measurement (accurency).
Second thing we've done is installing a pressure transmitter and connect it to the elektronics of the flowmeter because the higher the pressure the higher is the fault in accurency. See your manual.
For the rest you could send one a year back to the supplier to let it calibrate. But I don't think that's necessary.
Rudi
