Relay Circuit Design
I have a relay circuit which uses 3 power relays to control two AC motors and one AC light load.  The relays are switched through a 12V signal from a darlington array ic.  The two motors are alternating one on, one off every three minutes and the light load is continuously on.
The problem I am having is that the relay controlling the light will unexpectedly turn off after about 10 minutes of cycling the motors.  I have 100uF caps on the relay coil lines but the light relay still looses contact.
Any suggestion on where to start troubleshooting, power supply issue (30mA each through 7812 v-reg), capacitance, etc?
thanks
RE: Relay Circuit Design
send schematics
<nbucska@pcperipherals DOT com> subj: eng-tips
Does it come back on after dropping out? If not, how do you get it to start working again?
"Venditori de oleum-vipera non vigere excordis populi"
have you found the problem?
