Change text width in a block
Does anyone have an easy way of chaging the width of an attribute??
RE: Change text width in a block
Maybe autocad don't have this command, we should make a lisp program to change properties of these attribute.
Hi CadDraftee,
which ACAD-Version are You running?
I think a lisp still exist...
Lothar
ADT 2004
ACAD 2002
I was hoping that there was a lisp, i am running acad 2000.
CadDraftee.
I have a lisp. You can change size and width of an attribute. Mail Your adress.
Lothar
ADT 2004
ACAD 2002
You can use thw eattedit command or the battman command
already included with Autocad. Both are are also located on the Modify II toolbar.
BTW I'm currently using Auotcad 2005.
