Traverse Components in an Assembly
I am trying to create a treeview of all the components and parts in an assembly.  Listed below is the code I used (straight from SW help) and I am wodering why it will only go 2 levels deep. In other words, if you have a part in a subassembly it will return 'SubAssy1/Part1' rather than breaking it up into 2 model names.  Any ideas?  Thanks.
CODE
Sub main()
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swAssy                      As SldWorks.AssemblyDoc
    Dim swConf                      As SldWorks.Configuration
    Dim swRootComp                  As SldWorks.Component2
    Dim bRet                        As Boolean
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    Set swConf = swModel.GetActiveConfiguration
    Set swRootComp = swConf.GetRootComponent
    TraverseComponent swRootComp, 1
End Sub
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
    Dim vChildComp                  As Variant
    Dim swChildComp                 As SldWorks.Component2
    Dim swCompConfig                As SldWorks.Configuration
    Dim i                           As Long
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        TraverseComponent swChildComp, nLevel + 1
        Debug.Print Mid(swChildComp.Name2, 1, Len(swChildComp.Name2) - 2)
    Next i
End Sub
RE: Traverse Components in an Assembly
I would start by putting a "Stop" statement in the "i" loop right after you assign a new value for "swChildComp".  Check to see if this is setting as expected.
I did a debug.print there and got the filename "xxx/yyy" rather than "xxx".  It seems like the code is set up for an infinite number of levels but I guess not (unless SW posted buggy API code which could never happed :) )
I have used the code from swx, with additions, on a virtually daily basis for over a year. It recurses just fine. I would check to make sure that the assembly is loaded fully resolved; it wont 'tunnel' down thru lightweight or suppressed components.
Rocheey,
I checked all components and I am still getting the xxx/yyy.  I checked the nLevel and is it tunneling through correctly, but it is not displaying just the part as i would expect.  Do you get the xxx/yyy as is goes past nLevel = 2 ?
You seem to be confusing the text output of the component names with that of the filenames. There is no code above that references the component FileNames.
I think you are also confusing the text output (which contains 2 references) with a RECURSION level of 2.... in your debug statements, insert at the front a reference to the LEVEL (as passed in the function paremeter). This was originally in the SWX source.
The indentation level output in the DEBUG statements was to emulate a treeview, much like you are already looking for
Also, the code from SWX does NOT check to see if a component is suppressed; you may want to put your own code in there for that...
See my next post for a reworked version...
' Thos code will output an INDENTED tree,
' with The FileName and config name of each
' part file. It ignores supressed components
' and envelopes. The indentation corresponds
' to the level of recursion.
Sub main()
    Dim bRet                        As Boolean
End Sub
    Dim i                           As Long
    Dim ChildCount                  As Long
    Dim PathSpec                    As String
    Dim CfgName                     As String
    If ChildCount = 0 Then    ' could be a part file...
       If Not (swComp.IsEnvelope) Or (swComp.IsSuppressed) Then
            CfgName = swComp.ReferencedConfiguration
            PathSpec = swComp.GetPathName
            If CfgName > "" Then
                Debug.Print Space$(nLevel * 2), FileNameFromPathSpec(PathSpec & ""), "("; CfgName; ")"
            End If
        End If
   End If
    Next i
End Sub
Function FileNameFromPathSpec(PathSpec As String) As String
' strips path from FileName
    Dim SplitSpec As Variant
    Dim NumSplits As Long
    SplitSpec = Split(PathSpec, "\")
    NumSplits = UBound(SplitSpec)
    FileNameFromPathSpec = SplitSpec(NumSplits)
End Function
