Force update in catia v5 r13
Hi!
anyone knows how to do a forced update in v5 r13. I did it in v5 r11, just tipind c:force update in the command line, but i don't manage to do it in v5 r13
Thanx
RE: Force update in catia v5 r13
doesn't work on my R13 system either. ????
I do see the Force Update command in the drafting workbench and the assembly design workbench. VIEW + COMMANDS LIST. If you select it from the list, and OK, it does it.
If you do alot of forced updates, you might want to add the command to the tool bar, or give it an alias.
I take that back. I just did it with an assembly by typing in the command "c:force update"
Thanx Jackk! it works with assembly and drafting, but not with part design
