Error Estimate
Error Estimate
Error Estimate
I am using MSC softwares and I have few questions:
1) I would like to know what is the difference between Error Estimate Direct and Error Estimate Principal?
I got the following results and I would like to interpret them correctly.
Result Elem Stress discont. Volume_1, Error Estimate Direct - Layer (NON-LAYERED)
Entity: Element Tensor
--Entity ID----Scalar Value-
      5731718      2.625256
      8700383      2.825078
Result Elem Stress discont. Volume_1, Error Estimate Principal - Layer (NON-LAYERED)
      5731718      2.810257
      8700383      3.829084
At the same nodes, I got
--Entity ID----Tresca-
      5731718      51.472
      8700383      57.864
2) Does it mean that I have about 5 percent error on these nodes?
3) Finally, in order to get more accurate results. Is it better to add the Element Stress Discontinuity to my stresses? or it would be better to add the error on my stresses?
Result Elem Stress discont. Volume_1, Stress Tensor - Layer (NON-LAYERED)
--Entity ID-------Tresca----
      5731718      4.606151
      8700383      8.025431
Please note that, I may get following results:
--Entity ID----Error Estimate Direct
      5731718      2.625256 +  51.472  = 54.097
      8700383      2.825078 +  57.864  = 60.689
--Entity ID----Error Estimate Principal
      5731718      2.810257 +  51.472  = 54.282
      8700383      3.829084 +  57.864  = 61.693
--Entity ID----ESD on Tresca----
      5731718      4.606151 +  51.472  = 56.078
      8700383      8.025431 +  57.864  = 65.889
So, which approach is the best one?
Thank you,
AAY
http://www.geocities.com/fea_tek/asd/
