Spa on a wood deck
Spa on a wood deck
Spa on a wood deck
Hello-
     I have an existing wood deck made of 2x6's on pier blocks with 4x4 joists.  The pier blocks are approximately every 32 inches.  There was a small hot tub on this deck previously but I would like to upgrade to a much larger tub that will be about 5400lbs full (including occupants).  Any ideas if the deck is built to support this kind of weight?
