Table Balls Marking Sheet
Hi we have an Amada laser and the balls on the table are marking the sheets quite bad, do you have any suggestions to prevent this?
Jamie.
RE: Table Balls Marking Sheet
I would suggest using your Nylon Rollers if the machine is equipped with it.
msandoval
Be sure it's the balls, We have 5 Amada Punches, one punch/laser combo, The turret is the biggest culprit.
Take a new sheet of metal, roll it in then across the surface, look atthe scratch pattern, this should indicate where exavtly the scratches are happening.
