voltage regulating relay KVGC
hi,
Can anybody tell me that is it possible to configure KVGC relay to block RAISE & LOWER commands BOTH for overvoltage conditions?
For undervoltage, there is highset element for blocking both commands but can we have the same blocking option for overvoltage?
thanks in advance.
RE: voltage regulating relay KVGC
As in the manual, KVGC relay shall block the raise command only. Is it necessary to have a blocking for lower commands?
if so, why?
