speeds and feeds for .013-.060 endmills
Need to cut .030 deep slots in a hardened blade. not sure if ts or ss? max rpm our machine will go is 8,000. We keep breaking endmills. Any help would be greatly appreciated!
RE: speeds and feeds for .013-.060 endmills
Are your endmills HSS or carbide? How many flutes? What is the flute length?
Are you doing any plunging with the endmills?
By my calculations, slotting feedrates for .062 endmills should be in the range of .0001/.0002 IPT (inches per tooth or flute).
Manufacturing Freeware and Shareware
http://mrainey.freeservers.com
