Pleeesss How can I draw lines with point definitions from a database
I have a database (up to a thousand records) of points described with x,y and z fields. I am burdened with the enormous task of drawing a 3D line with these points.
Has anybody seen a code in VBA that can import database attributes and use them in the "line command"?
This will be a lot easier than entering the points manually.
Greg Akhibi
ABB Lumus Global
RE: Pleeesss How can I draw lines with point definitions from a database
Create a column that combines the x & y into a format of "x,y". This can be done with the concatenate command or a line similar to =A1&","&B1. Copy-clip the column. Inside of Acad start the Pline command, pull up the text window (F2), under Edit hit Paste. The profile will draw itself.
I have a lisp program import from text file data but only use for 2D ( x,y ) do not have z elevation.
It work well but some time have error. If you want to modified to 3D(x,y,z), I will send here.
CAD123 I would not mind having a look at the lisp program you talked about.
Akhibi
Greg Akhibi
ABB Lumus Global
