Rubber Bush - Metal to Rubber to Metal
Basic question - Molding of rubber to metal, Can somebody explain the best manufacturing process for an efficient bonding between them.
RE: Rubber Bush - Metal to Rubber to Metal
If you mean engine mounts, these are just steel inserts in a mould.
Jeff
I don't know how to get a good bond, I know this can be problematic. I'd guess the surface finish and cleanliness of the metal is paramount, and the correct primer is essential. If the bond fails at the edge of bush that is usually due to poor design - the fillet has to be carefully designed to minise the stresses in the transition.
Cheers
Greg Locock
This info is based on knowledge from about 5 years ago. With the very dynamic nature of structures within multi national companies, I can't be sure how or by whom these products are now handled.
pat pprimmer@acay.com.au
For additional information, contact Lord Corporation
at: 800-CHEMLOK (800-243-6565), FAX: 814/864-
3452 or write: Lord Corporation, Chemical Products,
2000 West Grandview Blvd., P.O. Box 10038, Erie,
PA 16514-0038.
Best regards,
Matthew Ian Loew
"Organizations cannot make a genius out of an incompetent. On the other hand, disorganization can scarcely fail to result in efficiency." -- Dwight D. Eisenhower
