Fog-Lamp ECU-Relay WHAT?!?!?
Hi Everyone - please help me out.
I'm trying to use a temporary-pulse ground-control switch (A fog-lamp switch) to activate an ECM which will then send power to a relay which in turn sends power to the fog-lamps.
I have NO IDEA where to find this simple of an ECU - something that will read a single, ground current pulse and use it to activate OR DEACTIVATE a separate circuit.
That, or I need an electro-mechanical latching relay that can use the same source-switch to open OR close itself.
I'm stuck - please help.
Jeffrey Knapp
WyoTech Automotive Technical Training School
www.JeffreyStephen.com
Jeffrey Knapp
RE: Fog-Lamp ECU-Relay WHAT?!?!?
I hope helps
