Mold seperation
Mold seperation
How can I make SolidWorks handle by-pass shutoffs. The Shut-Off Surfaces command does not locate all of them and even the ones it finds it fails to create surfaces.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Mold seperation
http://www.scottjbaugh.com/Tips_Tricks/Tooling_Split_With_Images.htm
Scott Baugh, CSWP
http://www.3dvisiontech.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
RE: Mold seperation
RE: Mold seperation
Meanwhile. ..
You can do it manually within the context of an assembly using the cavity feature.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
RE: Mold seperation
I was told last week that 05 will ship approx end of Aug/beginning of Sept
