Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...A lot of the information I've found at this site would've taken me forever if I'd have attempted to research it on my own. Thanks again."
Geography
chanson (Civil/Environmental)
6 Aug 04 12:47
What is the maximum deflection/bend HDPE can go through in a turn?
LHA (Civil/Environmental)
6 Aug 04 13:13
Depends on the diameter and application.
Small diameter, pressurized water and WW pipe can be deflected 5 degrees, max.  This is usually specified by the local utility.
Gas piping shouldn't be deflected at all, again, usually spec'd by gas co.
Large diameter gravity flow piping can quite likely tolerate deflection, but most often straight runs to junctions are specified.
dicksewerrat (Civil/Environmental)
6 Aug 04 22:50
You can run HDPE through a full circle. I think the turn radius is 30-40 times the diameter. Go to one of the websites and or get product info from a saleman. Phillips Petro. makes one of the common HDPE for gravity sewers. Driscopipe is one brand I've used.
Helpful Member!  Ag93 (Mechanical)
18 Aug 04 11:59
go to www.performancepipe.com formerly driscopipe and plexco.
Cold field bend radius of HDPE is function of DR and OD.  MINIMUM Bend radius for common drs are as follows:
DR9 or thicker = 20 times od
DR 9 to DR13.5 = 25 times od
DR 13.5 to DR 21 = 27 times od
greater than DR 21 = 100 times od
ie. 8 in. IPS DR 11 HDPE pipe can be bent into a circle that has a 200 in. or 16.7 ft radius.  Many muni's are starting to use HDPE for cul-de-sacs to eliminate the need for fittings.  Perfect application for it.  Good luck.
Close Box
Join Eng-Tips® Today!
Join Us             Close
