Adding a reference to a dimension
Is it possible to reference a dimension within the text of another dimension in a drawing? I know I can double click a dimension while creating text and it will add that dimension to the text, is it possible to do the same type thing within the text of a dimension? I have a round part that is turned to a diameter of 1.800, but the OD of it is a radius and I would like to dimension it as "1.800 OVER THE 0.500 RADIUS" with the 0.500 being picked from a dimension so it will be driven also instead of typing it in. Thanks for the help.
mncad
mncad
RE: Adding a reference to a dimension
Now you could probably add all that to a custom property and place it in a note within the drawing.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
