Create a lip in 2001
I cannot find the command to create a lip in version 2001? it is in the book but the program i have running does not display the item in the "tweak" meanu where extruding is used. Cna anyone explain this to me I would like to know how to create one in Pro E
RE: Create a lip in 2001
Hope this helps
What is a lip anyway?
Jeff
It's all part of life's rich tapestry!
Steve
http://www.sprdesign.com
Or right click on your Pro E desktop icon, under "short cut" tab and next to "start in" it will tell you what directory Pro E starts from.
Hope this helps
please I am sorry but I am new to this program and your patience is much appreciated.
Bill
pbindahouse@yahoo.com
Bill
Under "showing" it should show the path to the config.pro file in your start up directory, if not then click on the "open" icon and then browse to where you found it.
Bottom l/h corner under "option" type in "allow_anatomic_features" with a value of "yes".
Click "add/change" then "apply", at the top click "save a copy" icon and save the file. Now click "ok" bottom of page.
Hope this helps
