This forum as PDH for PE License???
Has anyone ever considered claiming time in this fourm as PDH hours for licensure??? Frankly, based on some of the "ethics" lectures I have been to in order to get my PDH credit and certificate, I think there is much more beneficial information here than I ever heard there.
Does anyone think that would be ethical or unethical?? And, what if the site management could give a certificate (e-mail) to members based on time spent in here??
Wild Idea, might be. Give some opinions.
rmw, PE
rmw, PE
RE: This forum as PDH for PE License???
As for claiming it as PDH, you can print out copies of your posts (date stamped) that prove that you were actively involved in the forum not just a passive bystander.
You will probally need some way to proved that you are the person that goes with the handle (screen name).
The more I think about this, the more I like the idea.
I would argue with them that Eng-Tips has certainly been a benefit to me, a resource, and to some extent a form of continuing education. But whether they would consider it a valid continuing education and how you could put a time value on reading a post, or posting an answer would be tough.
First, the same way I would "prove" that I actually sat through the lecture at some 'ethics' session set up by some entity, (rather than skipping out, or sleeping through it, and then just showing up for the certificate presentation,) it is an integrity issue.
Frankly, the only value in some of what I have sat through was that I did get the certificate, and satisfied my requirements. What I learned about ethics was pretty weak.
Valid points re the verification of the time and identity of our 'handles', but I have individuals on this site who know me personally, and know who goes with my handle. If the idea grew legs in this forum and had enough interest, I would present it to site management to ask regarding their ability to track the usage. They certainly can track things like how many times I log on, and how many stars I present to others, so they do have some tracking ability.
Further, if they did, and it flew, then, it would be value added for the site as a whole, so I would think that site management might have an interest in looking into it.
I was hoping that some member of this forum might be involved with the accreditation process for PE's somewhere, and could add some input to this suggestion. If anybody knows such an individual, please e mail this thread to him/her for their evaluation.
If there is enough positive response in this thread, I might e mail it to my state board for their evaluation.
You bring out some good points about it being tough, but I am old school, and that is when the "tough get going".
rmw
The "prove" that I spoke of was in determining the actual time spent - not the proving that I actually spent some time on it. Not the "whether" but the "how long".
If Dave can get some kind of tracking mechanism going where we could key on a button and get a printout of on-line hours - that would then provide the proof I think.
Then the question would be whether the state boards value the time spent here. You have no argument with me on that.
My association allows informal education hours, promotion of the profession as valid PD time.
I have no issues if ever audited, I’d simply print out a bunch of posts and submit them.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
David
John
I don't know for sure where you're coming from, but it is far from bogus. Many boards have a legimate category for "Literature review". I can't think of a single thing about this forum that doesn't satisfy the definition of "Peer-Reviewed Literature".
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The Plural of "anecdote" is not "data"
Your correct. I know of two states that will accept part of their CE requirments with documented activity in this form.
Continuing education means to some extent learning about new equipment, systems problems etc. Here these come at you at the speed of light. Even if don't solve them for other people you learn from trying and/or observing.
I fly but infrequently. Participating in a pilot forum would not count toward a flight review. Although I do not sell it I have an insurance license too. The state requires an organized class with 30 study hours including six hours ethics every two years. This is the model that makes sense for me. Internet classes are suitable. Exams are required.
John
As I understand the case:
Under NY rules, which went into effect 1/1/04, participation in this forum would not be eligible for PDH. PDHs are broken down into two types. The more valuable ones, of which we have to get at least 18 per triennium, require live instruction and a feedback mechanism, for example. The less valuable ones, of which we can take credit for no more than 18 hrs per triennium, are things like patents, self study courses, etc. I don't think that NY recognizes reading a text book, for example, for credit.
A problem with using this forum for credit would be validation of the qualifications of the participants. We have none. NY certainly requires some evaluation of the qualifications of a course instructor, for example, at least as practiced under PIE.
HTH
Jack
Jack M. Kleinfeld, P.E. Kleinfeld Technical Services, Inc.
Infrared Thermography, Finite Element Analysis, Process Engineering
www.KleinfeldTechnical.com
I could see counting *some* things on this forum but not others. Discussions specifically about ethics, for example, don't seem any less authoritative than the full-day ethics class I once took which was little more than group discussion of scenarios. And all the technical discussion I read could count. I don't think I could count time I spent posting or goofing around in the language forum.
(That said, I wasn't planning on using the forum anyway. I have more "Personal Development" than I know what to do with.)
Hg
