Linking a Driven Dimension
I did a quick search, but nothing came up. How can I link a non-driven dimension to a driven dimension? Picture an o-ring groove (gland) and I want the landing on either side of the groove to be the same width, with the inner diameter landing having a driven dimension (to the cavity I'm sealing). IT isn't really a necessary design intent, but it is irritating that I can't do that....or I'm having a brain fart.
RE: Linking a Driven Dimension
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
