FOUNDATION DESIGN FOR A HYDRAULIC PRESS
I NEED TO DESIGN A FOUNDATION FOR A 60 TON HYDRAULIC PRESS USED FOR CUTTUNG FABRIC SHEETS. TO TOTAL WEIGHT OF THE MACHINE IS 17,000 LBS.
ARE THERE ANY GUIDE LINES ON DESIGNING THIS TYPE FOUNDATIONS.
CAN ANYBODY GIVE ME A RECOMMENDATION ON HOW TO APPROACH THIS PROJECT.
YOUR HELP WILL BE GREATLY APPRECIATED.
THANK YOU.
THANK YOU.
RE: FOUNDATION DESIGN FOR A HYDRAULIC PRESS
Get as much loading information from the machine manufacturer as possible and provide that to your geotech and foundation consultants.
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
http://www.unisorb.com/default.asp
