Pump requirement for mulitple cylinders
I am using 4 cylinders to raise 2400 pounds. Each cylinder feels 1/4 of the load. I based my pump requirement calculations off of only one cylinder (I figured out what Hp was required to raise the load of one cylinder 1.2in/sec). My reasoning for doing it this way is: If each cylinder requires the same pressure, one pump can deliver it. The 4 cylinders can be configured with one pump and receive the same pressure. So, if P=F/A and P,F,and A are constant for each cylinder it would seem that one pump can do the job. The Hp equation I used only deals with Pressure, GPM, and a .0007 constant. It doesn't consider multiple cylinders. What is the correct way to figure Hp required.
RE: Pump requirement for mulitple cylinders
Cheers
Rajan
