Sorting data in same way as explorer
Is it possible to sort Excel data in the same way as Windows Explorer? I realise that Excel has it's own sort rules, but can these be modified in any way (other than just by checking different day or date options)?
RE: Sorting data in same way as explorer
any continuous range of columns can be sorted by criteria choosen while executing the sort command.
are you thinking about filtering data - the auto-filter feature?
please advise.
-pmover
I've got a list of filenames in one column in an Excel sheet (about 200 or so), and I want to sort this column (data/sort command) using the same character order as Windows explorer.
One problem though - I don't know what order that explorer uses to sort the data, I just know that it's different to that used in Excel.
Are you trying to sort these filenames by date? If yes, are the dates in a column separate from the filenames? If yes, are they formated as dates or as text?
Create another column, cause it to contain the ASCII codes for the file names, then sort on that column.
FYI - Excel's sorting rules are included in the Microsoft Knowledge Base article:
XL2000: Sorting Alphanumeric Text as Numeric Values
http://support.microsoft.com/default.aspx?scid=kb;en-us;214282&Product=xlw2K
Text and numbers are sorted differently, which is why I am curious about your formatting and search criteria.
- Elliot
