cheap efficient lasers
does anyone know of a cheap efficient (ideally greater than 80%) light source (preferably laser)? I'm after one for UVa 315-450nm and one for green light at 520nm +-20nm. The ones I have looked at so far are neither cheap nor efficient. I need a fairly intense source preferable (in the order of watts rather than milliwatts)....
RE: cheap efficient lasers
It all depends on your idea of cheap, of course. Are you seeing prices 2 times too high? 10 times? 100 times?
Why is efficiency a primary concern? One Watt is One Watt, irrelevant of efficiency.
CV
In the green visible, have you checked out diode lasers, guessing they are probably the most efficient.
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
Well, you can rule out lasers altogether. Your only hope is to use filtered incoherent light, as you would obtain from an arc lamp or tungsten halogen lamp. You will only get Watts if you add up over a large spot (as compared to a laser).
Will your application support that? If you give your required spot size and irradiance (W/cm^2), I can be much more specific.
CV
