light sources
light sources
light sources
does anyone know of a cheap efficient (ideally greater than 80%) light source? I'm after one for UVa 315-450nm and one for green light at 520nm +-20nm. The ones I have looked at so far are neither cheap nor efficient. I need a fairly intense source preferable (in the order of watts rather than milliwatts)....
RE: light sources
please define "cheap"
TTFN
RE: light sources
Is 80% a reasonable efficiency for a light source, any light source? I thought solid state devices were quite efficient but I haven’t seen any figures on it. Fluorescent tubes are very efficient compared to incandescents, but again I would have thought the actual production of light efficiency was horribly poor. I would be interested in seeing actual figures for light watts per electrical watt.
RE: light sources
EL panels are probably the most efficient lights around, but they're available in a limited set of colors.
As for the original poster, he needs a laser diode, but they're not cheap and not necessarily that efficient
TTFN
RE: light sources
by cheap I'm looking in the order of hundreds of pounds/dollars rather than thousands. The efficiency of most solid state lasers is in the order of 0.01%, I'd like to waste less energy than that...
