Tc through pond
Tc through pond
Tc through pond
I am trying to calculate a time of concentration through an existing pond. In the past I was told to consider the pond as a paved surface. Does anyone know of a standard way to calculate this, or if there is software to help?
Thanks!
RE: Tc through pond
ye olde TR-55 and TR-20
RE: Tc through pond
I was using TR-55 already.
RE: Tc through pond
Tc through an existing pond would certainly not be equivalent to a paved area.
The runoff would have to routed into the pond, with its baseflow accounted for (volume = 0 at water surface) through its outlet.  Its peak outflow is added to the peak of all bypasses.
RE: Tc through pond
Typically I take the Tc at the inlet of the pond then storage route the flow through the basin.
