ENGRAVING ON A CURB SURFACE
Is it possible to do engraving on a part that has been created with a (curb)surface?
The Wrap Text command doesen't work only on cylindrical,conical,extruded or revolved face.
I have SW2004SP0
RE: ENGRAVING ON A CURB SURFACE
Wrap will work on some of those types of features. I just tried it on a cylindrical and extruded surface... No problem. Conical and revolved surfaces are not supported. SW04 SP4.1
Your going to have to follow your other thread. to get the workaround.
Thread559-100606
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
