Allowable Bending Stress for Unbrased Tubes and Pipes
I am looking for a reference or a procedure to determine the allowable bending stress for laterally unbrased steel tubes and pipis sections. (particularly for Kl/r's up to 200).
RE: Allowable Bending Stress for Unbrased Tubes and Pipes
Whenever the Diameter to the thickness ratio is lesser than
2070/Fy
where Fy is to the number of ksi of yield strength of the steel, you can use the plastic capacity of the ring affected by the material strength reduction factor as the limit strength to compare with moments coming from factored forces of LRFD.
ASD for allowable stress design (service level design) is even simpler; if D/t is lesser than 3300/Fy, use 0.66·Fy as the Allowable strength to be compared with forces coming from the service level loadcases mandated in ASD.
